Operational Considerations
Consider the following when you use port and VLAN based attributes.
General Considerations
Only attributes that can be configured manually can be configured dynamically using EAP.
Dynamic cleanup is supported. When the last client to authenticate using a dynamic attribute is removed, the following dynamic attributes are also removed:
However, the following attributes can only be removed by disabling EAP:
VLAN-Based Features
Port-Based Features
The re-authentication flag and re-authentication period attributes origin can be either CONFIG or RADIUS. Different origins for re-authentication flag and re-authentication period attributes are valid:
For more information, see Extreme-Dynamic-Config.
